hi
Are TDG-BR250 3D glasses compatible with my KD-55S8005C Bravia TV?
i have been trying to sync them the glasses turn on but don't work any suggestions ?
thanks
iain
Hi there
The TDG-BR250 will not wotrk on your TV. You will need the TDG-BT500A instead. This is because the TDG-BR250 connects to a previous generation tv via infrared, whereas a newer generation tv uses bluetooth for active 3D.
Cheerd
