I lost the 360 access code provided with my soundbar- how do I get a replacement?
Hey CChivers what's the model number of your soundbar? And how did you receive the code?
I can't see as I have had a reply to my problem, I need help in getting 360 trial voucher, I have just spent £2000 and unfortunately I must of thrown my voucher away , is it possible to receive another code , Thanks Chris.
Hey CChivers, I was asking how did you get the codes, was there a voucher in the box? Or did you participate in a campaign?
I had the voucher in the soundbar box, really annoyed with myself after spending over £2000 with the rear speakers and subwoofer I must of thrown it out, is there anyway it can be replaced, Thanks Chris.
Hey CChivers, I'm sorry but I don't think so..
That's very disappointing, customer care hey.
Hi @CChivers This is a customer helps customer community. If you need a code from Sony then you need to contact them direct. Your fellow customers cannot help you.
Thanks for your help that's all I needed to know.
Hey CChivers, don't get your hopes high tho, and please let us know what they will tell you.
