I am planning to buy a STR DH750 System but I wanted to find out if you buy the speakers separately?
Am asking this because I live in Namibia and would want to import it.
thanx
there are no speakers in the set. You will have to buy some separately.
r_a_n_i
Thanx alot for the information @r_a_n_i
I just wanted to find out approximately how much is it for the whole set?
Is it about €500?
Here we go:
https://www.sony.de/electronics/av-receiver/str-dh750
I can't or will not comment on speakers, since this is very individual. When you have budget of 500€ for speakers only, it can be hard to find something. Maybe you should check for some second hand speakers.
r_a_n_i
