How to fix that it can be used as dialog is very low regarding music when watching a movie with blue-ray player of Sony
Gelöst! Gehe zu Lösung.
Hello @eripirar,
which speaker configuration do you have hooked up?
The dialogue is usually mapped to the center channel and if you have a center speaker you can raise that speakers volume independandly.
For some movies the dialogue is mixed a little quiet (e.g. TENET), so you have to raise the center channel a lot.
- Nic
Hello @eripirar,
- Nic
i have 5.1 conti, made a difference of 10dB between the center and the front speakers. Also increased a little bit the back speakers so that music is now coming more from behind and around while speaking is perfectly understandable.
thanks very much for the info
