Hi Bieomax
Having a look at the AMP, you should be able to plug in any audio equipment that supports a line-out function to the line-in on the AMP using component cabled (red/white).
See page 6 of the AMP's manual : HERE
Having a look around on the Sony site for products such as turntables, cd-players and other audio components, gives me the following page:
http://www.sony.co.uk/hub/home-sound-systems/range/audio-components
Unfortunately there are no audio components listed (of which I dont know why), other than AV Receivers and Speakers. My advice is to go into a Sony Centre and have a look and speak to someone in regards to whats on offer.
Hi Bieomax
