I recently purchased a US model of the STR-DN1080 when I was in the US. I was told that it will be OK to plug it into the European mains. (Ireland) Can anybody confirm if this is OK to do as I purchased the UBP-X800
blu ray in the US as well and had not problems in using it in Ireland, Can I simply change the plugs or will I use an adaptor.
Hi Masterchef9,
I would recommend getting in touch with Sony Support for advice on this.
Thanks,
Sean Mc
Nope, both only allow 120V max, if you plug it in Ireland, you will fry both!
you need to use a voltage converter
