Hi all -
I have the fantastic old TA-80ES pre-amp, want to replace its remote control, but cannot find an OEM replacement. Can anyone help with the correct remote codes, so I can use an after-market, learning remote instead?
So, the OEM R/Cs for this were:
I've seen a suggestion that RM-S703 might be compatible, if that helps, but cannot verify that.
Many thanks in advance for your help.
Hi there,
Hopefully a community member will be able to help.
Best wishes,
M
