The str-dn1080 has stored only the first device connected while in transmitter-mode, other devices added, have disappeared after a complete shutdown and power-off. Anyone else having the same problem?
Thanks for the tip, but since the receiver already has the updated software, a factory-reset did the job, now the receiver stores all the added bluetooth devices, also after a power-cycle!
Hi mirrormurr,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Hi Mirrormurr ,
Did you try updating the software: https://www.sony.co.uk/electronics/support/audio-components-receivers-amplifiers/str-dn1080/download... ?
Cheers,
The_Black_Rose
Hi Mirrormurr,
Great news! I am happy to know it's working again. Thank you for sharing the steps you followed.
Cheers,
The_Black_Rose
