STR-DN1080 low pass filter
profile.country.GB.title
nigeldoc
Explorer
Have had this receiver for some time, still have an issue with auto calibration constantly showing error 40 despite being in a totally quiet room, previous post here unable to resolve this, however i have another query.
My satellite speakers low range starts at 140 HZ so i would set the low pass filter  to 150 HZ.
When i look at the guidance for the Low pass filter setting it states if it is set to on then this will activate the filter with a cut off of 120 Hz.
As my sub woofer does not allow its own adjustment and i want to set the amp crossover to 150 Hz, should i turn the setting on or off.
If on will it over ride my 150 Hz setting and put it to 120, if I turn it off will it just ignore my manual setting?
Select the setting you want.
  • On: Always activates the low-pass filter with a cutoff frequency of 120 Hz.
  • Off: Does not activate the low-pass filter.
1 REPLY 1
HannahEd01
Community Team
Hi, I couldn't find anyway to enable the low bass filter on the 150 Hz, so as far as I can think you may try both options and see what happens?
