Hoping someone can shed light on this.
My daughter went to switch on her Sony Home Audio System MHC - V77DW and it won’t turn on. The stand by light just keeps flashing red and goes off.
Any ideas?? Thanks
Hi Hskerritt22,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Hi Hskerritt22,
The maximum she can do is try a power cycle (unplug from the mains for a few minutes then plug back in again).
If the issue remains, I'd recommend contacting her nearest service center: https://locator.sony/en_GB/servicecenters
Win_88
Thank you. We did try this and it did turn back on however the volume wouldn't work.
So I did it again and the volume came on!
No idea what that was all about but thank you for the advice.
