Anyone has any knowledge / ideas re this please ?
Its a Sony ST-D777ES DAB/FM/Am Tuner
Its borked itself 😞
I did a rescan this morning, as I was fairly sure that there were lots of new Dab stations.
I have an outside DAB aerial that is working fine - it was working before I did the rescan 😞
Now it is taking Ages to scan and Keep on getting stuck on band 11A, having found 33 stations already.
I have turned it off and on again, as per the manual.
I have unplugged it and then powered it back up
I have even unplugged it whilst switched on
All end up at being stuck on scanning band 11A
There is No way of skipping that band as far as I know
HELP!
I know a few years have gone by since you raised the query about problems with retuning sticking on 11a - but did you resolve this? I am getting precisely the same issue - wanted to add Scala - all the other 17 stations in this frequency are there but not Scala.
look forward to hearing [email protected]
thanks
