I am facing the following issues with my newly purchased SRS-X77and wondered if anyone can help.
1. When casting directly from the Chrome browser with a MacBook Pro, the connection/sound cuts every few seconds.
2. I also get the same issue as above when using Spotify Connect from a PC.
3. When I attempt to cast directly from an app on iPhone (TuneIn/Mixcloud) it will give the option to pick the speaker but upon selecting the speaker it just goes back to the previous page without connecting.
I have done a software/firmware update to V1.60.2892 but the problems persist.
I dont believe these issues are due to my internet connection as I can stream the same source through Airplay or bluetooth without a problem?
