Hi @Romipeki, welcome to the community.
If you are asking how to select Slovak or Czech language on the BDV-E2100, this can be done in the audio settings, using language codes available in the Instruction Manual.
Mick
Mick
Môžete mi napísať konkrétne ktoré lebo to skúšam a nic mi nemení jazyk.
Hello! How can i select romanian language? I am asking that because in netflix on bdve2100 i dont have subtitles in romanian, but in netflix acount accesed with other solution(smartphone or laptop) i have subtitles in romanian language.....what is the diferense??? Thank you
the setting of language is only available on DVD/BLURAY language/audio settings .....ONLY DVD settings on audio or subtitles....you can enter the code of language...
