Dears,
Im newbie, so it would be great if you can help me. I have heard sony zf9 soundbar in showroom. Decided to get soundbar with my xe8096 tv. The main question is if my tv compatible with dolby atmos or dtx? is it possible to listen it on netflix content? Or there is no possibility and content for such tv and soundbar? I have bad feeling that I will be disappointed hoping for much
Should I change tv or what can be done here?
Yes I understood that. But as I understand there is option to use some 4k TV box like Apple TV, Xiomi TV box and other in the middle of setup. So soundbar will be connected to tv box. So source will be received from box.
Or Im not right here?
Regards
Hi bilinis,
Having checked the table of supported formats, it says that the DTS X and Dolby Atmos are supported from HDMI 1 and HDMI 2.
So, I think it will work if you use an external box.
Cheers,
The_Black_Rose
