I have a Sony TC-77 Open reel to reel tape recorder, that needs servicing, I am looking for a specialist to look at it and sort it out for me as its an old model.
I live in North Wales postcode <Personal details removed by moderator>, does anyone know of a hi-fi specialist repairer in this araea?
There is no physical damage with nothing broken or missing, it simply has not been used for some years, and when the Function Selector is used the corresponding parts do not operate as they should.
Hi there
If you type your postcode into this webpage, them choose 'Home Cinema and HiFi" it should tell you where your nearest authorised repair centre is:
http://services.sony.co.uk/support/en/repair/asc
