Hi, I have a SRS-XB2 Extra Bass bluetooth speaker, purchased Nov 2017. The red charge light keeps flashing but the speaker will not charge. Have tried whilst it's on, off and have re-set - any ideas?
Hi @Gill2402 and welcome to the Community
If you have tried a reset then its probably best you give Support a call on
+44 (0) 2073652810
Here is some more info about the lights on the XB2
if you hadn't seen it.
