Hello, i own sony shake-33, but without speakers (i own only player), so i need to buy new speakers, my question... can i order passive speakers with 400w rms? or active speakers? ... do i need to buy speakers with 2200 rms? (its written on the box) ... thanks.
Hi Sonny,
Welcome to the community.
Since the connectors for the SHAKE-33 are very special, you’ll need to have the original speakers. Check out EET here for some replacement speakers and let us know how you get on.
Thanks,
Pascale
thanks for your answer, i bought this player without speakers and i cant buy speakers alone, i can buy passive speakers for good price with cinch connectors.... so.. what now?
Does it work, if you connect the speakers you bought to the "Party Chain" chinch output?
- Nic
kan man få forlænger kabler/ledninger til højtalerne
hvor
