Hi I would like to ask if how can I connect my Sony shake 33 to my Sony Curve TV? I can’t seem to match any cable
directly to each other. If I need to but a converter what type or name should I get? Thank you.
Hi rhoneyz3,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Hi rhoneyz3,
Welcome to our community!
The Shake-33 can be connected to TVs using a phono audio cable (red and white jacks) between the TV and into the audio in jacks on the back of the Shake-33. It depends really if your BRAVIA supports this kind of connection or not.
I wouldn't recommend using adapters as their functionality is not always guaranteed and may compromise the audio quality.
Hope this helps.
Cheers,
Batee5
