SPeaker fan on this is crazy, fpor example I am able to connect my bluetooth source and then if nothing plays you can hear the speaker fan noisily pushing air. is there a way ora part number I would like to replace it and it would be nice to be able to get that info
If any of you have met wioth this it would be nice as /I wouldlike to sor this, as i can make it an extension to the google home assitsn but when nothing is playing the noise makes for a less than desirable experience.
Hi there,
Welcome to the community.
We'll look into this and let you know what we find out.
Meanwhile, some of our members may have some suggestions for you.
Best wishes,
Ed
Hi UncleKeyPax,
I'd recommend you reset the speaker to factory settings as the manual explains on page 28 to eliminate any possibility of a software glitch. However, if that fails to fix the issue, your best bet would be to take them to a Sony service centre to have them inspected.
All the best,
Tenneen
