Hi
Powered the unit on this morning and there's a problem with the meter.
It goes to max, makes a buzzing noise, goes to min, makes a buzzing noise, goes to max ... and so on ...
I've done the reset and that hasn't cleared it. Powered off and unplugged - plugged back in after 5 minutes but still the same.
All functions are working fine just not this part.
Any ideas?
Thanks
Hello, processor, resistor or audio ouput volumes.
