sony CMT-G1Bip audio system on display f.w error -update please someone to help my ,where to found software-firmware for my audio system.
Hi borcesony,
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
Hi
I'd say try resetting the system to default settings using the below steps (from the Manual):
1- Disconnect and reconnect the AC power cord, and then turn on the system.
2- Press and hold STOP and ON/OFF on the unit for 2 seconds or longer until “RESET” appears.
**All user-configured settings, such as preset radio stations, timer, and the clock, are deleted.
Best wishes,
Win_88
