Why can I NOT create multi-room group using SongPal??!
SRS-X77 Speaker & STR-DN1050 Amplifier - Both Multi-Room/ SongPal Link compatible -
but on the app- the create group button is blanked out.
Have tried everything: 1) update firmware 2) update SongPal app, 3) disconnect all devices from Bluetooth, 4) reconfigure device wifi settings etc etc... Still the same.
Then....Tried calling Sony -twice, emailed once, was promised a return call. Still no response from them 3 days later! Might as well return the SRS-X77 for a refund, and give up on the idea of Sony MultiRoom!
Unless someone here can help? Many thanks....:)
Same problem here, i was hoping you'd found a solution 😞
