Does anyone know where I can find the codes used by the Remote for an MD313 micro hi-fi? The replacement remote is expensive, and the off-the-shelf programmable remotes don't seem to be able to control much more than on/off and volume...
They are actually listed in the product manual. You can't simply find any remote code for MD313 online.
That's very helpful - but, umm, how do I get hold of a product manual? It's not the same as the Instruction manual which can be downloaded from the Sony website...
