I've just bought myself a TA-FB940R QS model amp which is great apart from one problem.
I can only use the amp with Source Direct switched on as the speakers go quiet and crackle like mad if I switch it off.
I'd be interested to know if anyone has come across this before and if it's an easy/inexpensive fix?
Many Thanks
