do you have any suggestion beside usual like checking cables, switching on and off, checking type of line/phone switch etc for the next problem.
I used to have turntable working with bluetooth connection with one speaker.
I haven't used it few months and now I can connect turntable to the same and technics SC-C30 and other different bluetooth speakers but there is no sound.
Also I bought 3.5mm Male to 2RCA Female Jack Stereo AUX adapter to try to connect it to technics speaker system but also there is no sound.
All these (bluetooth and RCA connections) work with other devices like laptop, mobile phone.
Thanks!
For the connection with the SC-C30, the Switch Phono/Line Is on Line?
For the Bluetooth connection, Is the other devices in Pairing Mode?
Thanks Marino for suggestion.
I managed to make this working.
I first deleted all bluteooth existing connections from turntable and then tried to pair again.
And this worked with technics SC-C30.
However I got from my friend some sony bluetooth small speaker on batteries which works for the same turntable type as mine (And I checked this, this afternoon).
But with m turntable they can't pair.
But at least with my speaker system managed this work.
Regards,
rabgd11
