I need a Power Control Cable to connect a control amplifier Sony TA-E80ES to a power amplifier Sony TA-N80ES. Can anyone supply me one, or direct me to someone who might be able to? Or does anyone know how to make substitute for the original cable?
Best regards
gunnarbk
Hi gunnarbk,
welcome to Questions & Answers..:smileyhappy:
You may be able to order this from either your local Sony Centre or alternatively try from Sony's dedicated spare parts provider Nedis
Good luck..
Hello Thalamus,
Thank you for your response.
However, Sony can not deliver the cable, nor can they tell me its part no. I have sent a request to Nedis, but have not received any reply yet. I have also made a search in Nedis' on line spare parts catalogue for parts to the control amplifier and the power amplifier in question, and I have found one cable which is listed for both boxes. However, there is no picture, nor any further discription, so I do not know if it is the cable I am looking for.
I do have a question, though. Can you, or somebody else, tell me if the contacts on eather amplifier are supposed to be connected symetrically, i.e. right contact on one to right contact on the other, middle to middle, and left to left? If so, I think it would be possible to make a home made connection. So far I have been hesistant to try, but -- what do you think?
Best regards, and thank you.
Hi I am sorry to say that any accessories for this model have now reached service end, at 21 years old we are no longer maintaining the parts. If you have the old cable i can only advise you have it repaired or look on 2nd hand sites for a replacement, Sorry
