Recently purchased CMT-FX250 Micro HI-FI suddenly has no sound, worked fine for about 3 weeks. Display is fine all function buttons are working ok but no sound on CD or Radio. Display shows stations tuned etc...but still no sound. I have tried factory reset and re-tuned but stil no sound.
Steve Walker
Message was edited by: swalks
Oh, how unusual. I've been running mine for the last six months and have unplugged, plugged speakers in repeatedly after moving the unit between two rooms.
You might begin with removing the speaker cables from the unit (switch off first!) then replace cables and try again. I know it's a nuisance but it might be just a simple cable connection.
