Hi there
When I use a USB stick on the above unit it randomly forgets what track it was on when the stereo was last on. I don't go any further than 2 directories deep, and put a maximum of 100 tracks per folder. This happens whether I use a high capacity stick, e.g. 16GB or low capacity, e.g. 512MB. I tend to use CBR MP3 files, mostly 320kbps - no higher, and it doesn't happen all the time. I didn't have this problem before with a different stereo, so is there a firmware upgrade, or another fix?
Many thanks.
