I understand that Sony supports Aiwa products. I acquired an old Aiwa stereo system, and I need the manual. The model is #CX-81M. Can you point me in the right direction for a manual?
Thanks in advance.
Hi ingenius6,
Thanks for your message. We are looking into this and someone will get back to you shortly.
Thanks,
Pascale_F
Hi @ingenius6,
You might be able to find a copy online, but as the product is very old and hasn’t been digitized, it may be unlikely. I just did a quick search myself, but with no luck I'm afraid.
Cheers,
C
