x
profile.country.GB.title
Zoli-LND
Explorer
HT-ZF9 blurry menu
HT-ZF9 Menu on TV is blurry, pulsate. The same when playing songs and it's title is shown.
Is it possible that I scratched the audio OUT HDMI socket?
If yes, how to fix it?
If not, what are the other options?
Tags (1)
5 REPLIES 5
profile.country.DE.title
Peter_S.
Genius
Did you try a different cable? Maybe the current cable quality isn't best.
Zoli-LND
Explorer
Yes, I purchased a new cable. It is slightly better but the screen is still running.
Thanks anyway.
Zoli-LND
Explorer
I spoke all services and the result is that it is a faulty product and I can swap it to a new one.
Peter_S.
Genius
Thanks for letting me know.
Good luck with the new one.
Zoli-LND
Explorer
The new one works well.
I purchased the rear speakers too.
Boy, it is awesome. Like a cinema. Feels like being deep in the action.
