profile.country.GB.title
iankenyon1967
Explorer
HT-CT60BT soundbar
My sound bar will not power up ? It’s been working fine but this morning no lights, no sound etc? Is there any way of re-setting this ? Anyone else had similar problems
3 REPLIES 3
Sean_Mc
Moderator
Hi Ian,
This does sound like a hardware issue.
However, I would also suggest trying to reset the soundbar with your remote control. To do this press the following buttons in this order and within 3 seconds "Bass" then "Vol" and then "Trebble +"
Let me know if this helps?
Best wishes,
Sean Mc
iankenyon1967
Explorer
Sean
unfortnately tried this and it did not work
Sean_Mc
Moderator
Hi again Ian,
I would suggest getting in touch with the Support team for further help here.
Best wishes,
Sean Mc
