Hello,
I've recently purchased a Sony STR-DN1060 and want to set LFE level differently when I watch movies from when I listen to music...
Note I have movie sound coming in through composite and music sound coming in through optical...
I have not been able to see a way in the setup where I can specify a different LFE level depending on input, only in the main speaker setup (which of course then set that level for both inputs).
Any ideas?
I tried reaching out to Sony support to ask about this (since I don't own one to test with) and they confirmed that it's not possible unfortunately.
- JD
- JD
