Help! Extra speakers for HT-XT3 ?
profile.country.GB.title
lewis815
Explorer
I'm looking to get additional speakers for my HT-XT3 (for use both as additional speakers in the same room, but also placed around the house for parties to have the same audio from the TV) - Will the SA-Z9R Rear speakers for HT-ZF9 Soundbar be compatible with the HT-XT3 model?
If not, are there any that will perform the same function (or better?)
Thanks in advance!
1 REPLY 1
profile.country.DE.title
Peter_S.
Genius
No, the SA-Z9R can be used with HT-ZF9 only.
You can find a list of compatible devices here:
https://www.sony.co.uk/electronics/support/home-theater-sound-bars-home-theater-systems/ht-xt3/artic...
