Hi guys,
I have a problem with listening to some radio streams on TuneIn and I found that it is due to change of stream address from http to https which HAP-S1 problably doesn't support. Any idea to solve this? I think new firmware update would be needed.
Thanks
Hi WhiteWolf6,
Welcome to the Community. You could try contacting Sony Support about this.
Thanks,
Pascale
Hi Pascale_F
I did try it few days before. Unfortunately, there is no way to get feedback from Sony Support as they don't ask for your e-mail. You can send your support request anonymously only. 😞
Hi WhiteWolf6,
That's frustrating. Maybe try calling them in the morning then.
Thanks,
Pascale
