I have a Gigajuke NAS S55HDE and would like to record my CDs in WAV format but this will use a lot of disk space. Is it posible to increase the size if the hard drive by using an external hard drive if so how.
Yes it is, and I do this
I use a Buffalo LinkStation mini Network Attached Storage drive (from Amazon)
It's a hard-drive with a built in server which plugs into your router; other NAS drives are available, I think this was the first model which was DLNA compliant
Rip the CDs on my computer: the NAS is the default location for the 'My Music' folder
then point the GigaJuke to the NAS (one of the top level menus allows you to select a different server)
Hope you aren't having this problem
