Just bought the DN 1080 to drive my entire Sony setup consisting of 55" Android tv, and 9 different Sony speakers, only to find out that 1080 doesnt support Wireless surround.
The DN1070 supports Wireless surround, is Sony really releasing an updated model and cutting down the features ?
Any advice? Should I return the 1080 ?
Hi @SonyCPH,
We don't comment on future releases I'm afraid, but hopefully other community members will be to share some advice with you.
Cheers,
Cass
Future releases?
I am mentioning that the 1080 is lacking a very important feature that the 1070 supports.
Don't understand your reply
Apologies @SonyCPH, I mis-read your post so my reply didn't make sense :S
I can't comment on product development, but I will pass your feedback onto our engineers.
Thank you
any feedback ?
Hi @SonyCPH,
We've passed your feedback on - while it probably won't change anything on your product, it may do for future ones.
Thanks,
C
Ok, thanks for your reply.
I will return the DN1080 then.
