I have a DN1050 av receiver and I am currently having some fitted furniture in the living room where it is installed.
The fitted furniture will be an enclosed cabinet for the amp, however I have been researching clearance and cooling
Can anyone confirm if the av receiver will be OK in an enclosed cabinet? How much clearance should I give around the cabinet? Do I need to install and cooling fans and if so what temperature does the amp need to run at?
I may upgrade to the 1060 in future if that makes a difference
Thanks in advance
