Hi together
I have CMT-X7CDB RADIO, all seems to be good but I can’t connect to a WiFi. And also a update is not possible. It say to me all is up to date but when I check the software i see MC1.14 instead of MC2.08 . Is there something wrong.
Please help me.
Best regards from Germany 🇩🇪
Hogen1604
Additional some pictures
Hi there,
Please see more details here on how to download the Firmware update.
Best wishes,
Sean Mc
You are funny. As you see I try that way but it didn‘t work
but thanks for your answer
I have the same problem as the original poster. My device will no longer connect to modern Wifi networks. The website implies that I am running out-of-date firmware (the same version as the OP) but doing a network update on the device via wired LAN just says 'NO NEED'. Well there is a need as currently it doesn't really work as is clearly running old firmware.
Please can you indicate how the device can be updated using another method as the online update is obviously broken at this time.
I hope someone from Sony is also looking in that thread and maybe they have a solution for us.
That is my Software Version
