All MD's giving "C13 Read Error" hav followed instructions in manual to no avail.Can anyone help??
Hi If you have followed the instruction manual and it is still displaying an error, I can only advise an engineer inspects your hifi, it would appear to be a none user fix and may need new parts
Have you had any response to C13 error request.I am getting exactly the same after several years of no problems
Thanks for that , I will get an engineer to inspect.
