Hi All
I have a CMT-BX77DBi …. Definitely not new, but little used… DAB Radio works fine, but when I try to play a CD it reads the disk but when I press PLAY it starts but after around 30/40 seconds the whole thing just powers off. If I switch off the mains plug and then on again it works but does the same thing ?
Any ideas ??
Very happy to report that this issue is now sorted... after a lot of searching I managed to find the .pdf of the Operating Instructions and using those have done a Factory Reset... now all working properly again !!
Thanks for taking the time to try and help Hannah
Keith
Hey Kp22051, I couldn't find this model on Sony website, it's a 2010 model as per my search, still couldn't find anything useful to help you with, so if it's the correct model, I guess send it to the Sony engineers to inspect it.
Of course after trying the basics, a power cycles, testing with different CDs, etc.
Hi Hannah
Thanks very much for trying to help... I just looked at the unit again, I had taken the Model Number off the front ... when I look at the back it shows...
Back Plate
Front of Unit
I can find reference to this when I do a Google search ... but nothing that helps with the issue I have.
Thanks again for trying
Keith
