while making a reparing of the software of a Sony Xperia zx1 G8341 with the Sony Xepria Companion my internet connection falls down. actually my phone dont work, or any bottom and i cannont reboot the system by any way. i tried to intall minimal adb and Sony Emma Flashtool to reboot the system to fabricant settings with my PC (windows 10) but the phone is totally dead. the port usb read a connection but it makes errors in every read. i dont care about the information, i just want ty to recovery the device. thaks u all for reading and any help possible
@Bhaco95 before you try again to set your phone for a software repair, I suggest to put it to be charged for a couple of hours in turned off mode (however you could try to force it to turn off by pressing power button and volume up at the same time for over 10 seconds, 3 vibrations should be felt).
i try like you sayd but the same error it's showing up. i connect the hone to the Xepria companion, the software reconize the phone and after some minutes its shows a error in reparing
@Bhaco95 could you provide a photo of this error?
On the old forum, we've had some troubleshooting for Xperia companion. Until we get merged, can you check below:
https://www.verizonwireless.com/support/knowledge-base-203929/
