Is the XE85 series TV a 10 bit panel. I have tried to install 10 bit on my SKY Q box but it will only locate 8 bit? Is this TV not 10 bit ? Thanks.
Hi Harry, welcome to the Sony UK Community
Have you set 'enhanced mode' for the HDMI input you're using? You should find the option under External Inputs in Settings.
Mick
