I have an Activision flashback that connects to the tv with a dongle. I plug it in. It shows that it is hooked up in the input screen. Nothing happens when I choose the port that I am plug into. It simply closes the input screen
Did you connect a USB power supply to the dongle?
I have hooked up the dongle to a power source using the USB. It shows on TV to be connected, but nothing comes up.
