With the Xperia XA1 it says you can expand the memory to 256gb, does that mean I can pop in a 256gb micro sd card or is that the maximum including the internal storage thus meaning I would need an sd card with less storage capacity?
Hello @vargr1,
you can expand the storage with a 256GB card (i suspect you could even use 512GB, since the manual only states tthe biggest card tested tested at the point the manual was written).
- Nic
Thanks for getting back to me, most helpful. I think 256gb with be more than enough for me though.
