Hello Everyone,
This may seem a dumb question to some but I keep getting emails telling me that I should log in and "Update My Status". What is this all about and how do I do it? I've not been able to find anything dealing with status on the site.
Regards,
Toni
Hi Toni,
the email is just prompting you to update your status on the forum..
To do this click on either your Profile Picture or Q&A Username.
This will open your Q&A Profile Page.
Under your Q&A user name you should see a link 'Let others know what you're up to'
Click that link, a box should appear allowing you to update your status..:smileyhappy:
Yep,
I'm getting the same emails and like you I can't see anywhere to input a Status.
Your Status
Can someone from Sony support please answer this one?
Thanks
Hi Toni,
Thanks Thalamus.
I've done that. Mystery solved.
You're welcome doverrog, thanks for the feedback..:smileyhappy:
To everyone that replied, thank you so much for taking the time and trouble to do so. At long last I know what my status is, isn't it murder being a technophobe!
Best Regards To All,
Toni
Yep. I've got mine worked out now thanks to Thalamus.
Glad I could help doverrog..:smileyhappy:
