Hi I have these headphones and when I plug the charge cable in the red light comes on for a split second and turns off again not allowing me to charge them. Any help would be appreciated thankyou
Hi Colccfc,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Hi Colccfc,
Are you using the original cable that came with the headset? If that's the case, you could try to reset it by pressing the Power and the NC buttons during charging.
Regards,
Vanilla_
Hi thanks for your response have tried this but no good I'm afraid ☹😭
