I’ve recently bought 2 Sony Bravia TV’s they both connected first time to WiFi but over the past couple of days they keep loosing the network connection, when searching the WiFi point is there with full signal but they are just not reconnecting, have turned off tv & router & also reset factory settings on one.
any help please?
Thanks
From the Router settings you can try to change the Wi-Fi Channel, choose one used by a few other networks between 1, 6 and 11.
Manolo
