Hi
Bought this TV set KDL-32W705C 4 years ago and started using it, then left it in store after moved out. I tried to use it again last week and tried TUNING DIGITAL AUTO TUNING with antenna socket on the wall, and a Digital indoor amplified TV A/E, all failed, showing NO SERVICE HAS BEEN FOUND. There is no problem with connecting to WIFI and watching YOUTUBE.
I would be happy to get your advice.
Thanks
John
Most probably you have a problem with yours antenna, you may want to check with another tv if you have it available
