The pictures is turning wrong, cant move it right /left?
Hi there,
So I can try to help, can you give me some more details about the product you are using and the exact issue?
Best wishes,
Sean Mc
Sony xa2 - Norway
Hi again,
As this is the Sony Electronics community, I would advise posting your question over on the Sony Mobile community here for further help.
Best wishes,
Sean Mc
Hello @Ohb6969,
simply open up you gallery, select the image you want to turn and press the three dots in the upper right corner. This will open up a context menu where you can select the turn-option.
- Nic
