Hello all, I wish to sync up my old SWF-BR100 subwoofer to a 2 year old KD49XF8577 TV, it has the correct audio out and USB connections for the bluetooth dongle but when trying to secure "sync-up" between the tv and sub it does not! Having gone through the TV settings choosing subwoofer etc etc, it does infact state the model number of the this subwoofer!?!?
Any ideas folks?
Thx
Albie John
Win_88,
Many thanks for clarifying this, much appreciated!
Would have good for Sony to carry on supporting this sub for new TV models as consumers will probably upgrade the TV as opposed to the audio!
Regards
AlbieJohn
Hi Albie John,
Welcome to the community.
I'll see if I can track down an answer. Maybe someone else in the community has an idea in the meantime.
Thanks,
Pascale
Appreciate the welcome Pascale!
That would be great, just for added information i reverted back connecting to my other TV KDL-55W955B and it reconnects ok! both Bravia's so i would expect the SWF work with XF8577?
Regards
John
Hi AlbieJohn,
I don't think you're doing anything wrong here. The subwoofer is not compatible with your XF8577.
I found this article on the Sony website: https://www.sony.co.uk/electronics/support/televisions-projectors-lcd-tvs-android-/kd-49xf8577/artic...
Win_88
